Hi, I have a 156 2.4 129 kilowatts and onboard pc me instead of values ​​shows ****. Delete service also can not. Diag shows Rear wheel sensor - ABS warning lamp lights just 20 seconds after launch. Did not meet it somewhere?
When you set the time and after restarting, again to erase. Thank you for your help and sorry for the English. :confused:
Steel Ring attachment to pulse the signal sent to the ABS. Tendency for them to rust and subsequently split, sending a false signal? Also check the pick up lead to the sensor itself?
I thought that was a bad sensor on the right knee shows the trip computer instead of consumption ****?
Sorry, I guess your knowledge of automotive vehicle computer control is much greater than mine.
I'm sure someone her will be able to give you more accurate information and help in due course. My apologies for not being able to assist you in a constructive fashion.:(: :eek:
