S
Hi guys,
I am running an 07 2.2jts brera with 65k on the clock.
I now have the old classisc of pas noises on cold starts when turning the steering wheel.
I have not yet inspected the resevoir, but do you think now is the time to swap to green or is it too risky due to potential leaks?
Also, how many litres should i buy?
Opinions will be split almost 50/50. Research it (use search on this list) and make up your own mind. Valid arguments on both sides.
Its well worth changing the fluid for new but stick with red fluid if thats what you have in there, hopefully it will solve your issue, if it doesnt then consider a change to the thinner green fluid but remember it might cause the rack to start leaking.
I swapped from red to green a couple of months ago, and it solved the slight vibration / grinding I could feel when turning the steering at slow speed.
I used 3 litres when changing the fluid.
