1 - 20 of 135 Posts
Looking for a particular part? Need a price on a Accessory?
Please post here and I'll get back to you with price and availability as soon as I can :thumbs:
Gavin.
Hi Gavin,
I need an o/s headlight for a 147 GTA and Cosmo blue 428 touch up paint?
Ta
Gav
Hey bud,
PM me your reg number just so I can confirm the correct number for your headlight.
408 touch up no longer supplied by Alfa :tut: Although I've just emailed a supplier I know to see if they can supply one, I'll let you know.
Cheers.
Discussion Starter · #7 ·
Hi jayjayalfa,
Please PM your wife's registration number so I can locate the correct part number for your car.
And i'll get back to you with a price and what I can do it for.
Gavin.
Discussion Starter · #9 ·
haha come see me Mr Boyd!
I have one here you can try that I hope will work. Its certainly the shape of the new style, just unsure if you'll get a reception through it!
Apologies I hadn't got back to you when you had called. Absolutely maniac here, man down and all these other brands holding me back!
See you soon!
Hi Gav.
Don't suppose you are able supply a Passenger side driveshaft cup? This is the part that is attached directly to the gearbox and the driveshaft including spider joint slides into it.
I replaced my spider joint, unfortunately the cup itself is badly damaged. I can get you a part number and photo if needed.
Also need a rear wiper blade (forgot to put this one on my last request).
Discussion Starter · #11 ·
Hi Andrew,
Cup for passenger side p/n 55256720, retails at £110.15.
I would do it for you for £90. Get one in for tomorrow????
Gavin.
Hi Andrew,
Gavin.
Thanks Gavin. Looked up the part number and it shows it is for a 4c or 2013+Giulietta. My own part number search gives me 46308911. Can you please confirm which is correct?
I am happy to go ahead with whatever is the correct part so please send paypal invoice when you are ready :)
Cheers,
Hi Gav,
Thanks again for your excellent service. I am now in desperate need for 2 parts, I have already emailed you about 1 but I will post here too incase you see this first.
I need:
Multiair oil supply filter. Part no. 04892746
Multiair Actuator gasker. Part no. 04892649
Part no 31 and 32 on this image:
Discussion Starter · #15 ·
Hi Gav,
I need:
Hi Andrew,
Hope your well and the car isn't causing you too much stress :rant:
I've just sent you an email :thumbs:
Gav
Thank Gav. Have replied :)
Got the parts this morning. Thanks again!
Hello,
I'm after prices for a couple of bits please, both for a 2003 147.
First is the rubber strap thing that stops the fuel cap falling on the ground and rolling under the car in all the crud and diesel slime at the pumps... :rant:
And the second is a driver's door checkstrap. (3 door)
Thanks :thumbs:
hi
I have a Guilietta bought from Perth and the drivers side mirror is vibrating, not sure if its the mirror or just the glass, any ideas?
Harry
Discussion Starter · #20 ·
Hi Harry,
I've asked the service dept and I believe this is quite a common fault and would be the mirror glass that's needing replace.
I have a drivers side in stock £25 with your discount (exc postage).
Regards,
Gavin.
1 - 20 of 135 Posts
