1 - 2 of 2 Posts
· Registered
Alfa Romeo MiTo 1.3 JTDm (2010) - 95bhp
Hi All,
I've got a MiTo 1.3 JTDm2 (2010) that's reporting a P0747 DTC (Transmission Fluid Pressure Solenoid Stuck On) - I thought this would only apply to semi-autos??
Has anyone else come across this or know exactly how to locate this?
· Registered
Discussion Starter · #2 ·
UPDATE: I was using my generic OBD reader which gave the above description. The actual description (using MultiEcuScan) is P0747-78 Fuel Capacity Regulator (High Pressure Inlet Side) Stuck On - this makes more sense...... I'm assuming this will be the solenoid attached to the high pressure pump (was bench tested a few weeks ago when trying to diagnose a non-start issue and it seemed fine, but this was before this fault actually showed up)
1 - 2 of 2 Posts
