1 - 1 of 1 Posts
Does anyone know for sure if this code would stop my car from starting? ive had it a long time and left it as others on here said it never affected them either. I cleaned my EGR, MAP and butterfly valve put it all back together and now it turns but wont fire up, i have plugged in FES and this is the ONLY error.....but wouldnt that be too much of a co incidence that it only stops working after doing that? any ideas im getting desperate!!! :confused:
Ive checked all fuses, checked butterfly is open, checked all nuts bolts and elec connections 3 times over and connected to FES and as stated the only error is P0683 but that has been there a while.....
Just tested the actual connections to the glow plugs and they are all reading a signal on turn on off ignition, would this rule out the glow plug module? Tested the actual glow plugs and no 4 has had it the other 3 are ok....
1 - 1 of 1 Posts
