Hello dear alfa users.
I wish to ask for your help about my beloved vehicle. I have an issue for quite some time (because I haven't found a way to fix it yet) and it's about the temperature in the car. It's an Alfa 156 1.9 JTD (8V) 2002. So my problem is as followed:
I don't get any reading of temperature on my temp gauge BUT my cooling is working corectly (i've measured it manually and it activates @ proper degrees).
These things have been exchanged: 1) termostat, 2) temp gauge itself (which did nothing), 3) temp sensor (the black thingy below the stat). I don't know what else to check? Do you have any ideas? Is there a electronic issue (cables, fuses, etc.)?
Another funny thing - the part of the temp gauge that is working is the RED light when the temp goes ''over the edge'' (also tested manually when disconnecting the temperature sensor). Also, when I plug the car on the OBD there are no anomalies. I honestly don't know what to do.
Thank you for all the anwsers/ideas in advance!
