I have 8x18 oz super turismo with 5x100 and et38 from my r32 golf will they fit my 156gta with
330mm brakes if I use wobbly bolts and spacers.
Any advice appreciated.
Ta
would need the wheels machined out to 58.1 or the hubs done from 58.1mm
might get away with a narrow spacer for an alfa with the hub ring machined down to a volkswagen 57.1mm
Most aftermarket wheels use push in spigot rings to adjust the centre bore. You can order up a set of the right size and then fit then in place of the current ones. It is rare that aftermarket wheels are machined to exact bore sizes as so many manufacturers use so many slight different sizes, the cost of a cast for each tiny difference, or the added machine work to cut the centre bore eats into profits.
I had a set of TSW rims that came from a Honda. A set of new spigot rings and a set of wobbly bolts worked a treat.
yeah i forgot they were aftermarket rims .lol Not sure i like the idea of wobbly bolts though..
always swap mine to studs... but i guess they sell them so they are safe..
Discussion Starter · #7 ·
Cheers for advice will make some enquiries,should suit the gta and be lighter than the teledials.
