Hey guys, I have a 2.8 VR6 But the fans are not coming on untill its over the H mark. what would u guys suggest?
Waterpump is fine
rad is fine (dont seem to hold much water tho)
Thermersate is fine
Rad Sensor was replaced
any ideas ?? Same happened to my 156.
V
is it using water, has the head gasket gone??
dont let it get to hot or you will warp the head
If the fans are not coming on at about 95degC then it must be the low speed fan sensor, assuming the fans in the VR6 have the same theory as the 156
K
First thing is whether the fans are coming on. You should be able to unplug the wiring and bridge the connections in the multi-pin plug (paperclips and split pins are good for this) to make the fan run all the time. If the fan doesn't run with the contacts bridged it's probably the fuse or a knackered motor.
Once you've bottomed the fan, if it's still boiling up and the 'stat, rad and pump are definitely good, I guess it's time to look at the head gasket.
headgasket is fine. The low and high speed fans dont seem to work. Im going to pick up a new fan controler in the morning. *fingers crossed* My Alfa as been lowered to £750 if anyones intrested :)
