1 - 20 of 33 Posts
is there a contraption out there to buy(cheap) to suck out some oil.??
i have inserted a small plastic tube into the dipstick and sucked out some oil.
but short of getting the wife to suck out some more(she's good at sucking)
i wondered if there was anything that i could use that would be quicker ????
thanks.
i'm not drastically over. but i'd rather it be correct :)
O
thanks.
Yes, there is;
Pela Pumps, Oil, Liquid Extractors, Oil Extract
The Pela is a very useful thing, but probs £30 or so.......maybe you could ask if there is anyone local on the forum who has one. It would do the job in 5 mins flat.
Anyway, back to Storme's wife...............
Administrator
If you already have the pipe & want a quick DIY option:
Drill 2 holes in a coffee jar cover for the pipe, put 1 pipe into down the dipstick hole & into the sump, connect the other to a hoover ( other brands are available ) & let it do the work :thumbs:
Just make sure you keep the coffee jar upright & only feed the pipe connected to the hoover a small way beyond the inside of the cover so it doesn't suck in any oil from the other pipe or the bottom of the jar, also run the car for a few mins to heat the oil & it'll be easier.
When I did this I used a bit of tube down the dipstick hole and used a syringe to suck some out.
Syringes are easy to find around here, but I borrowed one from work to be safe.
Open the drain plug.
:)... i didnt want to get back under the car !!! :)
the pela pumps look like what i need....thanks guys.
and davidp's idea looks good as well.... i'll try that 1st, as it is only a diddy amount i need to remove....thx for the help/tips
yeah - give David's suggestion a try....even if only to prove he's good for something around here... ;)
As for the Pela.....I think you can get them in different sizes.......so if you wanted a once and once only usage (but presumably less moolah) then there is a small one (maybe 1 or 2 litres). Or you can get the biggun (like I did) and then you can suck ALL the oil out and do your own oil changes.......
Someone will now post to say......"but you can't get all the **** out unless you drain from the sump plug"........:D
Spend 30 quid, or spend a few moments jacking up the car and undoing the sump plug.....its a no brainer?!
hmmmm............yes..but
2 things...........be absolutely sure you turn the plug the right way.........and when tightening it, don't over tighten.
assuming it hasn't been rounded off etc. :confused:
S
Just drive it for a while. As long as it isn't silly overfilled, it won't be a problem. An extra 1/2 litre will do no harm.
Unscrew the oil filter, empty the oil out of it, then put it back on.
That usually works if the oil is only a little bit over the mark.
1 - 20 of 33 Posts
