S
I just bought a 2.0 Super without the master key. If I change it with the code box and keys from another car, will the ECU recognize it or will I have to change that as well? Is there a way of bypassing the keycoding?
L
Discussion Starter #2
you have a serius problem the code is also memorized in the ecu .the only way you cantry to over ride it is to open the ecu and find the eprom for engine and remove it for an hour or so ,it worked on my v6 (my brother in law removed a litle battery inside the ecu ).
hope i could be of help mojne
J
do you have any keys at all..???? if its just the red key thats missing i wouldnt worry too much (unless you need it one day)
S
I have got one red key for it, but that also looks a bit iffy (bent slightly))
B
I think the red key thing can be confusing - the normal keys are actually red, but the master key is dark red, more like maroon.
