Hi all,
Was just out topping up my fluids when i noticed what appears to be some oil residue around what i think is the intake for the turbo. Do you think this is just some vapour escaping from the jubilee clip or something more sinister?
Jock
had the same problem.
oil level must be higher then usual.
check oil level and dpf bar pressure ,
how many miles ?
when did you change oil ?
sounds like its just lose at the turbo entry neck, can you see play by wiggling it? just tighten/replace the jubilee clip, wipe it clean and keep an eye on it.
Car has only done 50,000 miles and oil was last changed in June - Will check for play and see if i can tighten the jubilee clip.
