Probably not too much to worry about - the official owners manual on my '72 spider talked about how the red oil pressure light may come on at tickover but should go off as soon as you get off tickover - and this on a new car. So it's plainly considered OK to see the light come on with Nords. The light is much more accurate and reliable than the gauge.
As others have said, make sure you are using the correct weight oil (was 20/50 on mine) and keep away from modern lightweight oils. I once used a 5W/30 in mine and the oil pressure dropped noticeably. Keep the oil topped up with regular changes you should be OK.
