Oil low....but isn't?
5434 23
I noticed my oil level ignition warning was showing I was low on oil today (for the first time ever) so dipped it to see how low I was only to find it was spot on the max as it has been since my last oil change.
Is this a common problem because in my experience the oil level shows accurately?
159 1.9d Lusso SW by the way.
1 - 20 of 24 Posts
Was your car parked on a hill, slope or slight gradient prior to starting her up? My light came on last week as the car was parked sloping downwards towards the front drivers side. the light came on when i started her up and did not reset till i had turn it off and started it again after a journey. did it again every day after using the same parking spot while on holiday. light does not reset until restarted after engine has warmed up.
It will warn you that way if the car is parked uphill and tipping a bit to the left, maybe the reading sensor is installed somewhat to the right of the oil tank! got that warning a few times whenever the car was parked that way. After driving for a bit and being in somehow levelled terrain, shutdown for a minute or so! It will read nominal again and no warning displays!
Thanks for the replies but I don't think I explained my issue very clearly. I'm not getting a warning, its the oil level light 'blocks' that come on when you insert the key fob in the ignition that's telling me I'm low, only 4 of the 6 blocks lit up. I've checked it on the level in places I've checked it many times before so pretty level ground. I suppose I'm concerned it could be telling me I have a pressure issue if the oil level is OK, not sure how the level system works? If anyone has any info on this it would be appreciated.:)
Discussion Starter · #7 ·
Thanks gents, I will relax for now! I was surprised with the reading because I have never needed to top up between oil changes in over 2 years thankfully. I wish I hadn't bothered to pop out to buy a litre of Selenia yesterday now before I dipped!
I'm told it can depend on how much is in the sump or if the engine is warm. Had mine serviced last week and the sensor was clearly wrong as it only had several bars showing. Best to just keep checking the dip-stick. It's about the only thing you can do on modern cars now anyway!
You need to be very careful with this.
If you misread the dipstick you can be in a whole world of trouble........
In my experience the on dash oil level indicator is vague and one missing bar (of the 6) can be over a litre in the sump (or maybe more!)
and the dipstick can read wrong if you don't know what you are looking at.
The stick goes through (IIRC) 2 bends before it hits the oil, the oil level when at max (and a fair bit below that) sits in contact with the bottom of the dipstick tube.
If you let the car sit overnight and pull the dipstick out you can have a reading of about 3 or 4 inches over max even if the level is low. (due to the oil being drawn up the tube)
If you clean the dipstick and re-insert it then pull it out again you might get an over full reading in one side of the stick and a midway between full and empty reading on the other side if the stick.
Always go with the low reading.....
When inserting the dipstick do not twist it round (as is the norm in some cars!) This will simply cause the stick to rub against the inside of the tube which has been covered in oil overnight whilst the stick was almost but not quite touching the inside of the tube.
Don't know if this makes a lot of sense, (it's late o'clock on Friday and I've been out all night!) but the physics of fluids in tight spaces basically means you should always believe the low reading on the dipstick (without rotating it in the tube) I trusted the on dash oil level and it cost me a turbo (which is still knackered so will cost me another rebuild soon, or no doubt a protracted and painful warranty claim against the original rebuild company)
Anyway,
If you check your oil on a reasonably level surface, with the engine stone cold, and you remove the dipstick and clean it before dipping it again without twisting it and both sides of the dipstick show you have a good (full) level of oil in then you have nothing to worry about.
any deviation from that and I'd worry...
Axe.
Heard or read anywhere that it's most accurate if you do an oil level reading after the engine has been running and let it cool off for about an hour or so. Warm/cold fluid phisic dynamics i guess. Not pretty sure, but i think i got that advice from my 159's owners manual!
ruby
I have been told by an alfa tech that on the 159 tbi when the sump is full and is on level ground the indicator on the dash is one bar down, if it is on max line on the dash indicator the engine has been over filled with oil.
Regards
Mick
Discussion Starter · #14 ·
Anyway,
Axe.
Thanks Axe that was great advice. I checked the dipped level again and one side of the dipstick was lower than the other. I topped up the level gradually until the level was the same on both sides (approx half a litre altogether) and now the level is on max on the stick and also reading full (all 6 blocks lit) on the dash.
Hopefully no damage done with that quantity but relieved to have this sorted. Thanks again. :thumbs:
I have this too, so nice to know that all is well. Plenty of oil when I checked again yesterday.
One concern though - sometimes my oil temperature gauge jumps down to low at 6 o'clock for what seems like no reason. Faulty sensor? Thoughts? No oil leaks, and car runs smoothly as always, other than a leaky water pump (and yes, definitely water when there is some on the road under the car).
Yes, faulty temperature sensor, really common fault on the JTS engines. Try cleaning the contacts that supply the car with the temperature signal (sensor wiring comes out of the sump), as oil tends to wick through the cables into the connector.
If this doesn't work you'll have to remove the sump, which can be a pain in the ass if you've got a 3.2, or I've made an aftermarket solution:
Feel free to ask questions if you have any.
Forgive my ignorance, or call me a noob lol, but where exactly are the contacts?
You have to take the unplug the connector going into the sump, there's a yellow security tab which stops it rattling off, and then you need to lift the locking latch over the tab.
After that spray it with a ton of contact cleaner, when I did this mine came out jet-black because of how much oil had wicked!
My oil level gauge doesn’t even show on the display anymore but 10 years ago when it was working, it would randomly tell lies so these days I just rely on the dip stick. The oil temperature gauge I think is associated with this and on mine, it works but only when it feels like it.
Yeah, the two functions are baked into one part. There's elements on a PCB inside the sump which can break over time with the heating/cooling of the engine oil; same goes for the temperature sensor. Mine wound me up so much that I ended up making the replacement above 😂
1 - 20 of 24 Posts
