Hi again guys
I recently had my engine (2.0 twin spark) replaced due to reasons below (see link)
http://www.alfaowner.com/Forum/alfa-gtv-and-916-spider/293231-engine-failure.html
I had an oil leak from the cam cover and had a new gasket fitted, That seems all ok now. However I am seeing some oil leaking from where the engine joins the gearbox. What do you think is causing the leak?
The garage (who supplied and fitted the engine) have said it is a big job to fix but not been specific. It could be main crank shaft oil seal so guess that is a big task?
Any ideas?
Thanks in advance
Jack
Any ideas?
Thanks in advance
Jack
