1 - 20 of 22 Posts
Hi my G is 7 months old, 3000 miles, multiair tb 170. I check the oil level every month, after 5 months 2000 miles it needed half litre of oil, 7 months 3000 miles on it needs another half litre of oil. I do a lot of short journeys most of the time, just come back from holiday in Dorset, so had some long runs. I don't use D mode that often. Is 1 litre normal with this engine, having read some of the threads a lot of multiair s don't use any oil. Will the oil consumption settle down after some time. Just need some advice thanks in advance:rolleyes:
i think it'll always be an oilburner now. lots of short trips and no proper running in. But some oil consumption in the first few thousand miles is normal. you seem to be over the norm though.
Ours has completed 12,500 miles, and only 5,000 miles since last service, oil & filter change exactly a year ago, during that time I have topped up about half litre which is more than I expected. Similar usage to you - fairly short runs with some long haul journeys.
You are saying 1 litre of oil for 3,000 - sounds very excessive, are there any obvious signs of leakage, or burning oil smell from exhaust ? I know there has been previous speculation regarding valve seals on multiairs so best let your dealer check things or at least let them know of your concerns whilst the vehicle is still in warranty.
Thanks for getting back so quick, i think a trip to the dealers just to put my mind at rest. Cheers for help.
There's no signs of leakage or any burning smell, in fact it's running really well. Will get it checked, and hope it settles down. Cheers.
there's a maximum allowable oil consumption of 400 grams per 1000 km, you're well under that so the dealer can't do anything. check the manual, it's in there (page 212 in my case)
I wonder what that is in English ? My book says similar, although since my last post I have actually taken the trouble to check the litre top up bottle I have, about 700ml remaining so not used half a litre, more like 300ml. I am a little neurotic when it comes to keeping the level at the top of the hatched portion of the dipstick, not really necessary of course.
The car goes in on Tuesday for oil/filter change and a few odds & sods, including a mysterious puddle that sometimes appears on the garage floor, dead centre under the car from time to time, whether wet or dry out, no loss of coolant though.
I check regularly if the level is still at the top aswell. And besides the intial +- half litre top up, the level has always stayed the same. mind you, the first few thousand miles the oil level was hardly visible on the dipstick. Only after I made another dipstick which is better to read was I sure that the level was halfway between min and max.
I bet it's water from the AC, this can drip for a good 15 minutes after shutting down the engine.
center of the car, but a good half meter behind the sump....
Yes - that would be about it, it's under where the bottom of the windscreen is located, thought it might be run off from screen washer but water from the AC seems more plausible. Thanks :)
I always keep it topped up to the top of the criss cross bit, used half litre first 5 months 2000 miles, was just surprised when I checked this month that it was nearly half way down again, which is by my reckoning nearly half a litre used. Will keep a check on it and hope it beds in. Cheers
Discussion Starter #14
The maximum engine oil consumption is usually 400 grams every 1000 km. During the initial period of use the engine oil consumption conditions should be considered as having stabilised after the first 5000 - 6000 km. Your right just checked manual :thumbs:
My punto (same engine without the turbo) used around a liter in the first 10'000 miles, then consumption dropped right down to 500ml between services (approx 9000 miles). That consumption doesn't sound worrying to me at all.
It's the a/c for sure. I have put a tray with absorbent under the car as the puddle is much much bigger on humid days. It's as if someone spilled a glass of water on the floor and my garage has ceramic tiles which become very slippery when wet.
Discussion Starter #17
Thanks makes me feel bit better:D
Ceramic tiles ? - how posh ! :) thanks for the pointer, one more item to cross of the "to sort list" I would imagine it's more of a problem where you are.
Yep :) it was used as a classroom in the past so has very good lighting and ceramic floor. The perfect place for detailing a giulietta!
1 - 20 of 22 Posts
