Isn't that a bit risk?As David said - and I tried to say +10deg C is warm - there is no need for 5W / 10W (winter capability -20C / -15C) You can go to 20W50
Quite literally... It'll be your gearbox and drive train and engine mounts that'll be taking the most beating. Not the engine...1st gear takes the most beating from me. Next oil change I'll put in 10w50 then?
As David said - and I tried to say +10deg C is warm - there is no need for 5W / 10W (winter capability -20C / -15C) You can go to 20W50 is you want to stick to 50 viscosity
No, it is NOT - 1st learn about oil - the 50 is the viscosity at 100degC. 40 is "thinner" than 50 and 60 still "thicker"Isn't that a bit risk?
Have to say, your posts do read a bit odd...I will rev her up at leat twice a day above 5k and usually change gears between 3.2 to 4.5k. Again performance and car care are my priorities not money when it comes to oil.
