So I was just about to order some wheels for my G and then i noticed that the offset for these wheels was ET32,
my question is will i need a 10mm spacer to clear the standard 1.6 brakes?
Zoo :thumbs:
you can't calculate the clearance between wheel and brakes from the offset, but in any event a lower ET value sits further outwards, and thus further from the brakes. a 10mm Spacer would make it an ET22 wheel.
I guess 10mm spacer would make it an ET 42 Wheel instead..
You can measure the ET value yourself.. Distance between Wheel center and Wheel face.. Just put on your new Wheel and see if it touches the brakes or not..
