1 - 12 of 12 Posts
My GT JTS 2007 it has developed an odd sound, only when the clutch is down.
It´s a high pitched sound, almost like a sough, a little fluctuating. Disapears when I release the clutch. After 10 blocks and 4 traffic lights, the sound is gone.
I recognize the sound of a worn fan belt (correct english...?) and that´s not the sound I hear. Any ideas?
Mine does the same, only when the engine is cold. Gone after a little while. I have put it down to the release bearing. my clutch took a bit of a hammering when i got stuck in a very soft, deep snowdrift a few weeks back.
mmm yeah i'd say its your release bearing on the way out.
out of interest. What would happen if i left this unfixed for a while? Will my clutch suddenly fail on me or will it gradually get worse for a few months? If it can wait untill april then i might be able to keep this car.
To change release bearing I think you'll effectively need to change the clutch. Might be ok to drive for a while longer, I have driven a car with a noisy release bearing for quite a while.
Thanks. I wonder, how hard would it be to replace the clutch DIY? since i have to drop the subframe to replace the ARB anyway....
My garage thought it sounded strange that the sound disappears after just a couple of 100 meters of driving. He said that generally it grows worse, but may disapear when the car is fully hot. He suggests that it´s the grease around the bearing that gets hard in the ice cold weather, and advices me to wait until the weather gets warmer.
Damn. You think the car gets warm enough in 300 meters? It only has 40 000 km on the clock, and I dare say I drive it very carefully (clutch wise)...
I think I´ll have to trust the garage guy for now. It´s not a matter of meters, it´s the amount of times I push down the clutch. If I pump it up and down 10 times at standstill, the noise disappears.
I might be back, though...
1 - 12 of 12 Posts
