As seems to be the case with some Alfas, you fix one thing and something else goes wrong. I've just changed the clutch slave cylinder - not for the faint-hearted and now I have an odd knocking sound/sensation.
Sometimes, when you start the car up there is a knock from underneath somewhere. Then, when going over a slightly bumpy road, the thumps/knocks can be felt through the floor. It's not horrendous but a definite noise. I had something similar before and it turned out to be the exhaust hitting somewhere underneath. A few adjustments and it went away.
I'm wondering if the same thing is happening again but I have the exhaust a vigorous wiggle around and it seems to be OK unless it's an up/down issue.
I was told it could be a bush on top of the bellhousing or an engine mount. Need to investigate further....
Any ideas!?
Dose the clunk happen when you come on and off the power?
Is it worse in lower gears?
Diff mountings are also worth checking.
No, just on start-up and going over bumps in the road. I wonder if it's the exhaust hitting underneath. It did something similar before. It's just that I've given the exhaust a good wiggle and all appears to be ok.
It feels like a bush of some sort. Will have to get it up in the air...
Have you checked the prop shaft doughnuts??
There is no vibration from the donuts but will check when I can get the car on a ramp!
