think you need an alfa lead set as there is a slightly different pin configuration..Thank you for your answer, basically I have purchased a Bluetooth code reader but it is not finding the ecu, so I'm thinking it is either faulty or I have ordered the wrong type, thanks again
Slight complication in that Maxiscan will still refer to it as OBDII as mine does..........but works fine on my 2003 GTV.There are no OBD2 Alfa at all.
OBD2 was a std for USA from 1996, Alfa withdrew from the USA before then.
EOBD is similar, but different, and applies to all EU market Petrol cars from Jan 2001 (Diesel later I think).
So your GTA is EOBD.
