R
Numan or any of you 156 owners had to replace the ECU because the airbag light stays on?
It only comes on when the passenger airbag is enabled, turn it off and the light goes.
Any advice would be gratefully received
During my time with AlfaRomeo, the most common problem with 156 Airbags was the connectors under the seats. Some owners had their ECU reset up to ten times within a year. Try to have the connectors soldered, and have the dealer reset the ECU once again. Allthough exchanging ECU's did happen quite often too ( Not very consoling, Huh ? :p )
All the best
Hoygaard
