1 - 13 of 13 Posts
i have FES, i can connect and clear codes on the airbag, climate and abs ecus using the adaptors (red,green,yellow) however i cant connect at all to the engine ecu(not adaptor). i have tried another laptop cable to no avail. ive used a multimeter most of the pins were showing 5-6V apart from 3
pin 4 0.1V
5 0.05v
8 0.0
not sure what they're meant to be, i'm not great with this sort of thing, :cry:
2002 interior facelift 2.4jtd 10v
Tim
What connector are you using ? a 16 pin eobd is needed
I don’t know if this helps but I use a ISO OBD-II / VAGCOM / AlfaDiag KKL Interface on my 2002 facelifted 156 JTS and have bridged pins 1-7-9 and also use switch to isolate pin 3 (airbags). I referred to FiatECUScan - Fiat, Alfa, Lancia ECU Reader / Scanner. I believe pin 7 is the engine ecu but I could be wrong.
You couldn’t go wrong by getting one of Rarebear’s modified cables if you can’t sort it out; but yes do check the OBD2 connection itself, maybe one of the pins is a bit corroded or too loose.
ive been greedy and posted on another forum. i think ive got people scratching their heads. im getting about 5vs through pin 7 so i assume thats live. ive tried someone else's laptop and cable so that rules those out. :confused:
Well the only thing I can think of then is that maybe pin 7 is a bit loose or you have selected the wrong type of ecu to connect to (easy to do). I had to fiddle with my connector one day to get it to connect and applied some dielectric grease; but if it’s not that I am at a complete loss.
FES is fairly straight forward so im sure im trying to connect to the right one, EDC15C7 which is right for the later 10v diesels, it doesnt make sense :confused: im pretty much at a loss too lol got to love Italian electrics. thanks for your help :thumbs:
Thanks. But definitely check those connectors before you do something expensive; I removed all my alfa’s OBD2 connector pins from the socket by firstly unclipping the yellow plastic cover, then using a small screw driver pushed down the little barbs on the pins to pull them out one by one. Once out I think you can squeeze the socket gap smaller with a small screw driver then all that’s left to do is put them back in the right order.
It wouldn't connect for me until I squeezed together the connectors, the only reason I knew my problem was the OBD2 connector was because I had connected to the ECU before. In your case maybe just try removing pin 7 unless you have about half an hour to spare.
My guess is that there is an error on the connector board, happened to me once (after 100 + modified cables), buy another cable from ebay (or buy a tested cable from me:). )
The connector contacts in the car , as suggested, are also suspect....
1 - 13 of 13 Posts
