Hi guys got myself problem with my 156 sportswagon.
Car somtimes will not start seems to turn over on the key okay but will not start & engine management light comes on. But give it a bump start or a quick tow it starts. Tried miracle cure of resetting ecu & management light goes out but happened again.Sometimes is ok for 4 or 5 weeks sometimes 2 or 3 hours. If no-one can help looks like expensive trip to auto-electricians.Cheers
Could be many things.....if the none-start is generally when the car is warm, the favourite is the crank sensor, a quick and cheap fix. Really need to get the fault codes read to give a better idea......
D
Is the code light coming on then going out ?
If its either not coming on at all or staying on the car wont start.
