At the weekend the Fan for my ac/heating etc made a really funny :wow: noise? the sound seems to come form the dash board / glove box. Any idea what the problem may be and if its a " easy " fix ?
:wow:
I think I have the same noise as you on my GT, sounds a bit like someone hoovering in another room.
Drives me mad.
I can get it to shut up for about a day, but it them comes back.
Let me know if you figure it out!
Good luck
I have had this in the past and it turned out to be small leaves catching in the fan blades ( how they got in there was a mystery)Remove the heater fan unit from under the dash on the nearside. It is held in place with a small self tapping screw. Twist the unit after removing the screw and it will drop out (bayonet type arrangement).
Hope this helps,
Mark
Cheers Guys
:eek: Thats the exact noise it makes GT-Rich.
Markp2 is this a fairly easy to do ? ie can be done in a morning ?
Are there are details/pics on the forum and where / how to locate and carry out this job ?
Yes pretty easy.
Open passenger door. Get on your knees outside the car(!) and look up under the dashboard from the passenger footwell. You should see a black plastic cylinder shaped thing. Remove the fixing screw, twist (anticlockwise I think) about 15mm and it should drop out. I would disconnect the electrical connector to the unit first.
Have fun, Mark
Discussion Starter · #6 ·
Thanks again Mark ,
No if i only knew where the electrical connection to this unit was ;)
Can i access from inside or is it in the engine area
