1 - 9 of 9 Posts
It's only just started but both off-side doors now make a loud 'bang' as they reach the 'stay' point of opening. The near-side doors open smoothly and stop at the correct point but the others are really loud. There's no sign of damage so I'm wondering whether it's just a matter of spraying some WD40 in there. Anyone else heard of this, and if so, what did you do?
It's probably the door check mechanisms. It's a common fault on 145/146s - I don't know if 156s use the same components.
Try tightening the screws above & below the check mechanisms where they go into the door; greasing the bar that goes into the door may also help' If it's the same part as the 145/146, however, it's likely that the bracket holding it to the door has broken, in which case replacement is the only permanent cure.
L
most likely the pin that acts as a hinge is worn & is allowing the strap to slap back/forth making that awful noise. You'll need to replace the complete check strap. I can change them in approx 10 min's using 'speaker-hole' surgery
door straps.....
£30 for the drivers door, £16 for the passenger door.
wd40 is a cleaner/dispersant. not an oil.
i wouldnt oil them anyway. it needs a decent grease.
as Lacken says, they are easy to change, and seem to affect all models.including my 147 !!!!!! :)
Well I got out my socket set and tightened the bolts up. Oddly only the bottom ones on each door were loose. The rear one, hidden behind a rubber seal was finger loose and once tightened the sound has al but gone. The torx bit I used was a smidge too small so I'm off to Halfords in a bit to pick up bigger one just to give them a final tightening. WD40 didn't really help but I suppose it was never going to in this case.
Thanks for the advice and I hope this helps someone else out.
That's an indication that they may be broken. The mounting screws screw into two lugs on the check unit, which are formed by bending a pressing some 5mm thick at right angles. Because the press tool leaves a sharp edge in the corner it leaves a stress raiser which the bending operation exacerbates, leading to fatigue failure in prolonged operation . . . probably more than you needed (or wanted!) to know!
The torx bit I used was a smidge too small so I'm off to Halfords in a bit to pick up bigger one just to give them a final tightening..
It'll most likely be a Ribe driver you need . . . Halford's probably haven't heard of them!
1 - 9 of 9 Posts
