Hi
Before I rush off to finally get the awful rattle fixed by my local AR dealer when the cam belt is changed, I thought I better check what experience anyone else may have had with the Gadget that controls the variable valve timing
Re: I really joined because of the noise
Hi, welcome to AO - sounds like you need a new variator :)
When you start the car does it sound like a diesel? That'll be a knackered variator then.
It can't really do any harm but get it replaced if you're having the belts and tensioners done anyway.
It should cost about another £100.
And restore the performance which has like as not deteriorated.
Does it go away after a few seconds running, worse irst thing in the morning or when cold?
Thanks guys
All the info and sugestions appreciated.
The car is booked in Wednesday 21 Feb. Will let you know how I get on.
