Hi, was wondering if anyone can shed some light on this problem.
Basically after charging my dead battery ( in situ ) and a couple of attempts at a boost start, I found I had killed my ICS and also the speedo/rev counter are not working ??
I suspect ( hope ) its a fuse blown somewhere, but cannot find any that are gone. I have since had to replace the battery, so all connections are good and everything else seems to work.
Any help would be most appreciated :)
Thanks Mark... was hoping I wouldn't have to do that :eek:
Since the speedo is affected too, thought there might be a common fault elsewhere ?
The fuse on the back just supplies the radio, tape player and CD changer (if fitted). I've just had to change that on mine but the ICS was still working.
Tried another fuse in the fusebox just to be sure?
Discussion Starter · #7 ·
All fuses in pannel are good. There is however an inline fuse on battery lead. I've read a couple of threads that a bad connection here can be problematic, but the fuse checks out and all connections are tight.... anyone know for sure what this fuse is protecting ?
