I've replaced the master cylinder & the slave cylinder all bled through ok clutch arm on the gearbox is moving ok but just grinds when trying to select gears:confused:
Banned
I'd say get the gearbox off and investigate, unless of course you havent toped up the fluid or bleed it.
If the movement of the clutch release arm (flack shaft to some) is OK then I'd think either your gear selection linkage (the stuff connected to the gear knob) has fallen apart, or the clutch spring plate has lost it's fingers dur to a siezed release bearing. Start by removing the battery and tray, then you can inspect the selection linkage (which I think is most likely at fault).
