Simple question this... Can anyone confirm whether there is a warning light for dipped beam on the phase-2 instrument panel? I wonder if mine had one and if it has blown. Tried shining a torch at the cluster but couldn't see the icons except the left/right indicator arrows.
Since fitting LEDs to the front fog lights, I now drive around during the day with them (and the LED sidelights) on as 'daytime running lights'. There is a warning light for the sidelights and another for the fog lights. As you know, the foglights are an extremely low beam and can't illuminate enough to drive by, but hopefully are enough to be noticed from a distance.
When it gets dark, I twist the headlight switch to turn on dipped beam, of course.
Problem is, the following day I tend to forget to turn the headlights off, since I don't see a light to indicate when they are on. I usually realise when I pull up behind a van
I can't remember whether my Spiders or some other model had a green dipped-beam icon.
-Alex
-Alex
