Help please. A new fault has developed, I select cruise control and green light comes on but when I twist stalk to engage nothing happens. Any ideas to solve?
Thanks. Clip on clutch was replaced yesterday. In what position should the switch be and what does it look like?Check the clutch pedal switch positioned just over the pedal, knocks the cruise control off when the pedal is pressed.. If it's out of position it'll prevent the system working.
I had the same issue. I took the switch apart in the end and cleaned up around the edge of the plunger and where it slid into the switch. Took no more than 10mins (I was taking it slowly as well). I found it to be a really easy fix. Might be worth having a go as no doubt the garage will just order a new switch anyway and charge you for fitting!!Got it. Tried pulling plunger out but moves back a touch and returns to original point ie not far enough out. Don't want to snap it off so might take it to garage. Thanks.
Thanks for advice, will try tomorrow when there is light. I did consider taking apart but was unsure how to do it as couldn't pull white switch out of housing, any steer? Also did you use anything in particular to clean it?I had the same issue. I took the switch apart in the end and cleaned up around the edge of the plunger and where it slid into the switch. Took no more than 10mins (I was taking it slowly as well). I found it to be a really easy fix. Might be worth having a go as no doubt the garage will just order a new switch anyway and charge you for fitting!!
Yep, works perfectly thanks. As an aside had a chap come to speak to me yesterday in the car park for a good half an hour about the GT. He was praising its looks, in and out. He left feeling enthused and wanting to get one. How many <£4K modern cars would generate that interest?Is the cruise control working now?![]()
Thats what we like to hearYep, works perfectly thanks. As an aside had a chap come to speak to me yesterday in the car park for a good half an hour about the GT. He was praising its looks, in and out. He left feeling enthused and wanting to get one. How many <£4K modern cars would generate that interest?
