Hi all
hope some of you can help, I have just taken an alfa 166 v6 and put it into a gtv tried to start it today pressed the fob and the immobiliser light went out and the keycode light went out but it does not turn over, not even a click from the starter solenoid, there is power to the starter, battery fully charged 30 amp ign fuse ok
If the engine is immobilised through the ignition then it will still crank so your problem is most probably electrical, provided the engine is not seized up for some reason but to check this, do the following.
First try to turn the engine by hand. If this works, then check wiring, voltage at the starter motor, earth connections, etc. It may be a faulty starter motor, but if it fails to turn by hand then you may be sitting with a mechanical fault.
If you only replaced the engine only, and kept the ecu and alarm unit then it should start.
My next trick would be to disconnect any and all cables from the starter motor/solenoid and connect a jump lead from the +ve battery terminal to the starter to see if it spins. Connect that +ve to the solenoid to "fire" the starter motor itself.
