1 - 2 of 2 Posts
hi guys just brought a clutch slave for my 33 1.7
i currently have my engine out on an engine stand and i want to rip my old clutch slave out and replace it how do i do so ?
So I assume you have drained the hydraulic fluid already as the engine is out and the clutch slave is still attached.
There is a large circlip on one side next to the rubber boot.
You'll probably need a pair of 90 degree noseclip pliers (one of those that open when you squeeze the handles) to remove the stiff circlip. Then it should just slide out of the other side.
Read this as it will help a lot when installing it. But I've never had to fill and bleed it again. Others will chime in here I imagine.
Alfa Pages :: View topic - Clutch slave cylinder replacement
1 - 2 of 2 Posts
