1 - 20 of 28 Posts
S
My trusty chamois has died. It was old, but soft and lovely and I miss it. It finally tore in half today when I tidied up the garage and it had got itself wrapped around a circular saw blade. What a way to go!
Now, I've used one of those big microfibre towels before and it was useless. Just moved water around rather than drying the car. I have maybe one more use in an old Flash Autodry canister to keep me going. So needs to be purchased in the next few weeks as the car is getting grubby fast at the moment.
What do those in the know recommend for being extremely cheap, really good and fast in use?
Andy
PS - cleaning the car isn't really my bag, it gets washed before shows or when it starts looking a significantly different colour.
Administrator
Lateral thinking:
If you get some of the 'quick wax' products that you spray on to a wet car and then dry off with a microfibre cloth, they make the cloth much more effective at drying. And your car is shinier too.
And for the flash quickdry thingy, I have recently read of people using water softerner filters intended for fishtanks with their hose to achieve the same end.
Administrator
I got a Microfiber Madness Dry Me Crazy recently, it's not exactly cheap but excellent quality & soaks up loads of water, I'd say it'd probably dry 2 cars :thumbs:
S
Any views on a silicone squeegee blade thingy?
Look easy to use.
Administrator
I've never used one, I've seen plenty of advice saying to avoid them though as they can easily scratch your car if it picks up any grit on the blade.
I bought The Reaper from Autobrite direct on TommyWho's reccomendation: The REAPER Super Plush Drying Towel - New HELLSHINE range
Top marks for this towel! Can get the whole car dried in about 7 mins, no effort at all! Absolutely 100% will never touch a chamois again, this big red towel changed my life...
Also machine washable which is nice (no fabric conditioner mind! Sparse use of detergent, hot wash, and some white vinegar in the conditioner tray), just make sure to put it through on it's own as it will stain everything pink/red!!!
Microfibre towel and aqua wax or equivalent all the way. Easiest way to quick dry.
+1 Brilliant bit of kit
And I can vouch for the wash advice as all my microfibre towels are now tinged with red!
Bought one, used it once, now relegated to drying house windows only. Nuff said!
Use Protex drying towels after using AquaGleam filter for the rinse. 30 p.p.m. as the 0 p.p.m. is depleted too quickly.
C
I use a waffle weave drying towel, lay on bodywork and pull towards you. Soaks up water and less prone to surface scratching -vs- chamois.
See. cleanyourcar.co.uk. 38" x 28". £10.95. Can put them in washing machine as required.
I still use my trusty chamois.....which has holes in it but does it's job as intended.
As stated above I'd lean away from the silicone blades....I've used one at work before to quickly dry off a car and put a lovely big scratch all the way along the door :paranoid: .
Micro fibre cloths imo are ok for a final wipe over after polishing, but are naff at drying off water after rinsing.
I've used a genuine chamois to leather off for years until I discovered the ultimate synthetic replacement which I have used for the past four years or so which is brilliant.
You'll not easily find them in places like Halfrauds and other auto factoring outlets, but in my opinion they are far superior to genuine chamois skins,micro fibre cloths,or those stupid hard and stiff when dry multi-perforated synthetic sheets of crap.:tut:
I've got two of these excellent synthetic leathers for drying off now, because they never go hard or stiff, always absorb masses of water, are easily washed, and dry out quickly soft and flexible.
My two have never torn or got holes in them over the years they have been in use.
But watch out as the original was the ultimate, and I reckon the additional I have bought later on is probably a copy, good enough, but not quite good as the original purchased four years ago.
Lecture over and done.:D
Oh! and you can ring them out as hard as you would when twisting a gooses neck at Christmas.:D
Administrator
Micro fibre cloths imo ... but are naff at drying off water after rinsing.
You need to try a dedicated high quality microfiber drying towel, that'd change your opinion.
Chamois trap any dirt, dust or grit particles against the paintwork of your car, which will cause scratches and swirls. A plush microfibre drying towel stops that happening. Also you can dry an entire car in a couple of minutes without and streaks or the need to wring it out.
Think I'll have a bit of that ^^^^^^^very impressive.
I've used poundland microfibres clothes for years, thought they were fine and a chamois that has lasted what seems decades.
Time for a change:thumbup:
Proper microfibre towel. They are not all created equal. Make sure you dry it well after using it. It will feel dry, but still actually have a a lot of water trapped in it if you don't let it dry well after a wash.
1 - 20 of 28 Posts
