If the display continually shows four bars " - - - - " then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.Tanks, but does not accept 4541!!!
Could I have the code for the following please - BP 7643311316
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case. Like BP3311 X XXX XXXX???! Post it for the code!Could I have the code for the following please - BP 7643311316
Hi, try code 1133Sorry, must have been half asleep when I sent that.
Try BP331147076554 please.
hi, try code 5652BLAUPUNKT 815 BP331147080391 Ta very much in advance
Hi, try code 6464Hi
Need a radio code , BP669871731200 , 7646698317 Please And Thank You
Thank you , Can you do GTA ones ?Hi, try code 6464
We can try!Thank you , Can you do GTA ones ?
Hi, try code 4123Hi, I need the radio code for 815BP533254384960, 7 645 332 316 please. Thanks
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case. Like BP6302 X XXX XXXX???! Post it for the code!Hello,
I'd kindly like to ask you to give me the code to the radio:
Alfa 939 CD SB05
65260108773
BP-Nr: 7646302316
Fiat-Nr: 1560730930
Thanks in advance!!
Hi, try code 3611Please radio code for Alfa Romeo 147:
Blaupunkt 815BP532769145820
Many thanks!
Hi, try code 1653Hi. Can you also help me with the 156 model Blaupunkt
815 BP037822564437
7640378316
Thank you!
