Need a Radio Unlock Code? Ask here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1255097 Views 15802 Replies 4527 Participants Last post by  bogege
You need the model number and serial number...
Only for 147,156 and GT factory fitted Blaupunkt radios.. POST 2001.
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case. Like BP0376* * **?!! Post it for the code!
code eg BP037822578162
One of our friendly helpers will be along with a code for you shortly :)
  • Like
Reactions: 5
15421 - 15440 of 15803 Posts
Hola! Necesitaría el código de desbloqueo de la radio BP 7643 301 316. GRACIAS!
  • Like
Reactions: 1
hello,can you help me. my serial number is 815BP532757541116.pleaseee im very bored when drive🙁.(alfa romeo 147).
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case. Like BP3301 X XXX XXXX???! Post it for the code!
Hi, try code 4154
Hi, try code 4154
its work dude.thanks a lot🤲🏻
  • Like
Reactions: 1
Hi, I'd love it if you could help me with a radio code for an Alfa Romeo 159, Blaupunkt radio:
815 BP630267668168
EDIT - Oops I just noticed this is the 156 forum. My apologies.
815 BP630267668168
Hi, try code 5213
is there someone that can help me to find the radio code for my Uconnect 6,5 installed on my Alfa Romeo Giulietta?
Its a Harman Radio
Model: VP4 940 Version EU
Serial is T00BE264590677
Its a Harman Radio
Hi, try code 8489
Hola. Tengo la numeración de la radio. Me ayudáis con el código de desbloqueo? Gracias
BP 330147139715
BP 330147139715
Hi, try code 5233
Hi I need Radio code for my 156 could you please provide it to me
Bp037834850869
Bp037834850869
Hi, try code 6353
Hello I need a code for BP037822581305.
Thanks!
Thanks!
Hi, try code 5651
Hello i need a code for Alfa 156 high cd BP037834848704 (I have the card with the code in it but that doesn’t work because i insert it then it says wait and stays like that for a while then it asks for the code again)
If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " then " - - - - "
Enter CODE in the order it is read:
For Example, To Enter Code 1234
Press Preset 1 then 2 then 3 then 4
The Code will Enter Itself Automatically
Hello i tried that with the code in the card but it didn’t work i thought maybe there was like a universal code for reseting it or something like that because the code i have just doesn’t work.
I'm looking for a Radio Code:
  • Model
    • Alfa 939 CD SB06
  • BP - Nr.
    • 7 646 302 316 / (Blaupunkt) Alfa 939 CD SB05
  • Fiat - Nr.
    • 156 073 093 0
Thanks, have a nice day!
See less See more
