13881 - 13900 of 13901 Posts
Blaupunkt
BP149144474261
7 612 001 497
Is this what you need?
Hi, try code 8386
Code Entry as Follows:
Switch Radio On - Display Shows
" SAFE " and then " CODE "
Rotate RH Tuning Knob to Select 1st Digit
Press RH Tuning Knob to Enter
Rotate RH Tuning Knob to Select 2nd Digit
Rotate RH Tuning Knob to Select 3rd Digit
Rotate RH Tuning Knob to Select 4th Digit
If the correct code number is now shown
Rotate RH Tuning Knob To Select "Return"
Hi, could I possibly have a code for my GT stereo please. BP 646 698 316.
I hope that's all you need, many thanks in advance!
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case.
Like BP6698 * * ** ?? Post it for the code!
Hi, apologies I've picked the wrong number to quote you.
How about BP669871730361?
Thanks!
1999
Greetings To All! After removing the terminal, the ICS requested a code that I do not know.Help me find out the code for my Simens AR1000042595/03
You need the model number and serial number...
Only for 147,156 and GT factory fitted Blaupunkt radios.. POST 2001.
Then enter your serial number ... starting BP
code eg BP037822578162
One of our friendly helpers will be along with a code for you shortly :)
BP037834857621
7640378316
