I've tried that twice not good,
Tells me to wait then quite some time after goes back to code.
But thanks for your effort.
Check again if the serial number is correct?If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " then " - - - - "
Enter CODE in the order it is read - eg:
For Example, To Enter Code 1234
Press Preset 1 then 2 then 3 then 4
The Code will Enter Itself Automatically
Ok I'll give it a go but wait prompt stays on fo around 1 minute then goes back to code, I'll try that tomorrow and thanks againIf the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
If this does not happen, the worst option remains! In the past the radio was decoded and the original code was changed!Ok I'll give it a go but wait prompt stays on fo around 1 minute then goes back to code, I'll try that tomorrow and thanks again
Hi need a radio code please bp532857624384 thanks TimRe: Need a radio code? Ask our friend Audiotech here...
Hi griff,
There will be one more number on the sticker or stamped into the chassis of the radio. It will look something like: BP*378****
Post that number here and the code will be yours as soon as i next login :thumbs:
try code 3545Hi need a radio code please bp532857624384 thanks Tim
try code 4566Hi Bogege,
please help me with BP630261745728.
Thanks in advance
Ralph
Hi, try code 2463Please help, my wife has bought an Alfa 147 on a 54 plate and whilst she loves driving it around it has a few issues, i've replaced the battery and starter due to age but now the radio needs a code and it wasn't supplied with the car, can anyone please help?
Serial number is: BP330147125636
Thanks in advance
Hi, try code 6313Good day,
Please can I have a radio code for the following Alfa 147 Radio
BP937817589748
try code 4635Dear Bogege,
The code of our 156 Blaupunkt radio is missing. The number is BP037834857710. I will be grateful to receive the code.
Many thanks!
With kind regards,
Ottavio
Thanks for the fast response, it's the right code!👍try code 4635
I have a alfa 156You need the model number and serial number...
Only for 147,156 and GT factory fitted Blaupunkt radios.. POST 2001.
Then enter your serial number ... starting BP
code eg BP037822578162
One of our friendly helpers will be along with a code for you shortly![]()
Main Dealer or a Decoding Service only for this code!hi u have a code for alfa gt navigation ? View attachment 951670
