try code 6316Hi, stereo packed up on my Alfa 147 so found a replacement on Ebay but no code supplied, can anyone help please? Numbers are:
BP937838732128
7 649 378 316
Many thanks!
BP937838732128
7 649 378 316
Many thanks!
I have a 2004 reg 1147.You need the model number and serial number...
Only for 147,156 and GT factory fitted Blaupunkt radios.. POST 2001.
Then enter your serial number ... starting BP
code eg BP037822578162
One of our friendly helpers will be along with a code for you shortly![]()
I need the model number and serial number.. from radio.I have a 2004 reg 1147.
The radio code went blank when I had to replace the car battery. I don't have the radio out of the dashboard.
Can I give you the car serial number?
ZAR937000 03208610
Thanks if you can help.
Edward.
Amazing it worked! Thanks so muchtry code 6316
OK Thanks.I need the model number and serial number.. from radio.
Post serial number ... if starting BP ***???
7643311316Re: Need a radio code? Ask our friend Audiotech here...
I have just purchased an Alfa 147 I(used) and am needing the radio code for my head unit an Alfa 937 HIGH 7649378316 the number below this is 785293234 which I presume to be the serial number, is it possible you can help or advise?
regards
griff (London)
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case.7643311316
Like BP3311 * * **? Post it for the code!
BP331157188270BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case.
try code 4125BP331157188270
ıts worked 🥰 thank you. You are the best.try code 4125
Ok I've got the radio out.OK Thanks.
I've now figured out how to take out the radio from the dashboard. It is the factory fitted model.
Once I've got it out I'll send you the serial number.
Thanks for your time.
Edward.
try code 1556Ok I've got the radio out.
its a BlauPunkt BP 93 78 38 75 03 01
try code 4654Hi,
I have a 147 GTA, we had to change the ECU/battery etc. We do not have the correct code for the stereo unit. The BLAUPUNKT serial number is: 815BP937732188687. Can someone provide this?
Sorry we can't help!Добрый день. Помогите пожалуйста с кодом. Альфа ромео 166 2002г. Огромное спасибо. View attachment 947747 View attachment 947748 View attachment 947747
Hi - thanks for this. Am waiting for "WAIT" status to finish so that I can enter the code. Will let you know.try code 4654
