13621 - 13640 of 13675 Posts
Добрый день пожалуйста помогите мне сел аккумулятор скажите что вы лучший в этом деле)))) BE2569W5019790
Hi there, can somebody help me with the code for my 156 GTA.
Bp-Nr:
7612001088
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case.
Like BP1491 * * **???? Post it for the code!
Now I found the correct nr, was on the side of the unit.
BP149126445041
Try these two codes once! 1813 or 2415
Please note that code entry is only possible in the order shown. If the display continually shows "SAFE" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" SAFE " and then " CODE "
Rotate RH Tuning Knob to Select 1st Digit
Press RH Tuning Knob to Enter
Rotate RH Tuning Knob to Select 2nd Digit
Rotate RH Tuning Knob to Select 3rd Digit
Rotate RH Tuning Knob to Select 4th Digit
If the correct code number is now shown
Rotate RH Tuning Knob To Select "Return"
