7643301316 br nr
Prod Fiat 735301823
Can help code?
Prod Fiat 735301823
Can help code?
Sorry we can't help!Hi all, I have an Alfa GT 2004 with a radio/navigation which I bought from a damaged car, but there is no code..
Can anybody help me?
Thank you in advance 😘
View attachment 946191 View attachment 946192
try code 1211
try code 6641Hello,Alfa Romeo 156,2004 BP037822597688 please kod???thanks
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case. like BP3301 * * **???? Post it for the code!7643301316 br nr
Prod Fiat 735301823
Can help code?
Okay, thank you very much for the reply, which service would you recommend for this?Sorry we can't help!
Main Dealer or a Decoding Service only for this code!
thank you 👍try code 6641
I do not know what services there are in your country! You can try here ........ Decode Database - DND Services LtdOkay, thank you very much for the reply, which service would you recommend for this?
try code 2165815BP936
How? There’s nowhere to enter it? Sorry, noob here 😞try code 2165
Please note that code entry is only possible when "ENTER CODE" and four lines is shown in the display. If the display continually shows "CODE ERROR" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.How? There’s nowhere to enter it? Sorry, noob here 😞
BLAUPUNKT made units have 14 letters+digits long serial numbers and are printed on the label or engraved on the metal case.Hola, puede ayudarme, pero el código ¿cuál es el código para ar 147 jtdm ? Gracias
Bp 7647697316
Hi i need help with codeRe: Need a radio code? Ask our friend Audiotech here...
Code - 4361 :thumbs:
try code 1652Hi i need help with code
BP439251245138 (14Digit)
7644 392 316 (10 digit)
much appreciated
Shane
try code 1243Hi there
The radio/cd player in my Alfa 156 needs a code - can you help me please?
Numbers as follows:-
815 BP037822588452
ALFA 156 HIGH CD
7640 378 316
021613
Thanks in advance.
Gezza
it works thanks a mill may you have a blessed new yeartry code 1652
Thank you (it's night time hear now so will try in morning!.) Happy New Year to you! 🎉🎆try code 1243
