21 - 40 of 12569 Posts
Re: Need a radio code? Ask our friend Audiotech here...
Hy Audiotech, I need your help, 815 BP 037834862492 and BP Nr. 7640378316.
Hi Audiotech,
Ok finally got the tool required and managed to get the stereo out!
There are two BP numbers on it, i will give you both.
BP NR 7640 378 316
BP 037 845 003 407
SJB
Hi Audiotech
Can you help with a code for Alfa 147 radio!
BP937817296071
021613
7649378316
Many thanks
Silver500
Excellent.
Radio is Alfa 937 High
Prod Nr 7353018230
BP-Nr 7 649 378 316
BP 937 8387 40915
Thanks very much
Adam
I have a Alfa badged boot mounted, 6 disc cd/radio player to which I have lost the code. I am told it may be a Clarion unit. The serial numbers stamped on the underside of the body of the radio unit is as follows:
AL 0932X0943628 and
V 90943628C
are these numbers sufficient to prpvide me with nthe security code? Many thanks.
J
Please can you provide me with a stereo unlock code for my Blaupunkt Alfa Romeo 156 standard stereo?
Serial #: 7640378316
Product #: 1560342090
Side Label #: BP037834844791
021613
I would really appricite the help.
Be good if you could help
Have 98 GTV 3.0 24v with a Clarion head and changer in the boot.
Had to change battery and no code.
Clarion has 1133298600 PU9907AQ Unit has engraved CC might be LL 0278U0011293
thanks
Hello, and thank you for being there,, i recently purchased a 1993 alfa romeo spider veloc and am in need of the radio code. Please see the information you need in order to get this code as follows: SN# 7710584 Model # 0060897430 there is also another number not sure if you need but it is: C# 3633ez1 i appreciate your help. Again thank you... M. C. O.
the serial # 7710584 - model # 0060897430 and one other number not sure what it is, C 3633ez1. it is an 1993 alfa romeo spider veloc, thank you for your anticiapted help in getting this code. mel
Hi, wonder if you can help.
bought a 03 plate diesel 147 two weeks ago & get a occasional warning that the battery charge is low, so i've decided to replace the battery & i haven't got the stereo code.
The label on top of stereo says
bp nr 7649378316
prod fiat 7353018230
a151
The side label says
bp937838535081
alfa 937 high
7649378316
021613
hope that this is enough info & that you can help.:D
hello, Radio sn# 7710584 Model# 0060897430 C3633EZ1, 1993 alfa romeo spider,, need radio code, pelase. thank you:cry:
Hi, hoping you can help me too?
I have a 147 with Blaupunkt original stereo.
Serial number BP 937 617 446 789
Thanks in advance
021613
If I have figured this out correctly, yours should be 1345
Let me know if it works? Iv just done mine myself.
bp nr 7649378316
a151
The side label says
bp937838535081
alfa 937 high
7649378316
021613
yours should be 2321
Hope its ok me printing these codes? audiotech hasnt been on for a while. If Im breaking rules, please let me know :thumbs:
Hi - I've lost the code for my stereo - do I need to take it out to get the serial number?
