Hi griff,I have just purchased an Alfa 147 I(used) and am needing the radio code for my head unit an Alfa 937 HIGH 7649378316 the number below this is 785293234 which I presume to be the serial number, is it possible you can help or advise?
regards
griff (London)
Hi,Can you do the code for Kenwood units, model RX-350 as fitted to japan new alfa156s. Wil remove to get the s/n if if you do have these codes
edit: if these even require codes. I ahven't disconnected the battery yet
Code = 4621 :thumbs: :thumbs:thanks for getting back audiotech, the other number on the sticker is BP937817288247 is this the one you mean?
regards
griff
Just a standard set of DIN or U pins avalable @ around £2 from all motor accessory shops or ebay. It can also sometimes be done with a bent piece of old wire coat hanger or 4 pop rivets etc.......Hi Guys,
How do i take out the stereo, it has four little holes in each corner, i want to take it out without damaging it, is there a specific tool?
SJB![]()
Too easy ???? ..I need a code so I can safely disconnect my battery without losing my sound.
Its a pretty standard radio /cd unit original equipment and currently working.
codes and numbers .. found these on the set by "carefully " having a look.
Alfa 156 High CD 7 640 378 316
Or the same numbers
BP NR.
7 640 378 316
and also this on a side label..
815 BP 037 822 589 210 .
I would appreciate it if anyone can help with a code for this and how to enter it .
Code - 4361 :thumbs:Too easy ???? ..![]()
Hi,Hi there , Please could i have the radio code for AL0932w0318159 , v80318159
Keep up the good work
