That is from one of your pedals, thats a common problem.
When i am correct there should be a spring to, its part of a spring system.
And yes it works without.
Its off the top of the clutch pedal. If you look up there you will see a tube it slides into and a metal arm on the body the plastic part locks into, if I was you I would check if any of your clutch cylinders are leaking as this will occasionalyy cause the part you have shown to fall out if tension is lost for a moment.
Ah ok , thanks both for that. changed the master clyinder about 2 weeks ago I must of knocked it loose and not noticed.
Cheers guys ?
