Hi
Recently had my GTV V6 mot'd so that's been a year of ownership with a car that's hard to beat for smiles per mile
I have done about 3500 miles in that year so it has had plenty of use (now reading just over 99k).
It's a black phase 1 with 17" teledials, Q2 diff, Ragazzon exhaust and polybushed rear suspension. I didn't know the differences of phase 1/2/3 before I went to buy one and now I have one I actually prefer the phase 1 dash although the seats could be better as I feel I'm sitting on them rather than in.
Mot required new rear caliper, discs, pads and handbrake cables but no advisories.
Work I've done in past year (most during the summer) has included:
Replace thermostat, radiator, one of the fans (was noisy), a headlight (broken fixing), coolant hoses, air filter housing (rusted bolts). Also various missing/rusted screws and bolts.
Clean up and paint bottom radiator panel and fan housing (both rather rusty)
Replace battery.
Replace bootlid struts.
Repair splits to rubber intake hose with glue and silicon sealant (had been taped up). still a bit of a bodge I know but have seen thread on how to replace with silicon item.
Remove phase 2 grill and replace with phase 1 item with new badge
Replace speakers all round and fit new head unit
Remove centre console and remove decayed rubber coating (used brake fluid method) but have not painted it and just left natural plastic finish which I think looks fine. Also replaced any missing screws and fixed broken instrument fixings and replaced gearstick gaiter while it was all out.
Driver's side interior door handle loose, managed to take up slack in cable to fix and also repaired broken end of door pull handle.
Jobs to do include fit new headlight foams, fix air con (wished I'd replaced condenser with new item when radiator was being replaced), replace handbrake gaiter. Could do with other rear caliper replaced sooner rather than later too. New dampers on list aswell.
Next immediate job just a wash, is looking a bit grubby.
Well that's about it for my first year of GTV ownership, I'm sure some people have similar stories of work done or some of you lucky enough to just need a service.
this was a much longer post but as i hadn't clicked a "terms and conditions" box I lost the whole thing...maybe not a bad thing for you to get shorter one
Replace battery.
