My 135 TCT MiTo
1490 Views 17 Replies 6 Participants Last post by  Jpe61
I'm gonna try and drop a few lines here every time I tinker with my MiTo. Just for sh!ts and giggles.
It's a white 2011 135hp TCT, bought it in april 2022 with pretty much even 100.000km on the clock. Fourth alfa in the family, second MiTo. Yea, should've known better 😂
So here we go:
1 - 18 of 18 Posts
· Registered
Discussion Starter · #2 · (Edited)
I decided to check the multiair filter:
Hood Motor vehicle Automotive tire Automotive design Grey
Wood Finger Musical instrument accessory String instrument accessory Everyday carry
...and cleaned it:
Bicycle part Nickel Metal Fashion accessory Electric blue
To be honest, I was quite surprised to see it in such a good condition (the pic looks horrible, but irl it was very clean). No metal particles, just some staining and a couple of what looked and felt like (I didn't taste) very small plastic shavings.
A couple of puffs of brake cleaner, some wiping and all was good. Half an hour job maybe, plus my standard 15 minutes of "is it too tight - too loose" ocd when putting it back...
Automotive tire Automotive exterior Motor vehicle Automotive wheel system Gas
As you can see, it did go in quite a bit deeper than it originally was. Should I have left it at the same depth, it would have been almost hand tight... I did not torque all the way to the spec of 27Nm, I'll check i for leaks in a week or so. Felt snug enough.
· Registered
Discussion Starter · #9 ·
I ordered new floor mats a week ago, since the OEM ones were sparking bitter critique from my daughter for their worn out look.
And today they arrived: https://www.amazon.it/gp/aw/d/B01M1IJ7FS?psc=1&ref=ppx_pop_mob_b_asin_title
Gotta say, I'm really happy with the overall appearance/percieved quality, and needless to say, the price is right. Cheap even. The bottom side has a texture that stics to the car's floor, so the mats don't slide around at all (front mats have attacment holes that snap into the buttons on the floor).
Only downside was that would've loved to get ones with Alfa Romeo or MiTo logo, but this brand didn't have that option.
· Registered
Discussion Starter · #12 ·
Oh, forgot to mention: the rear mat (first pic) seem "loose" or oddly shaped, but it is actually perfectly correct, following the form of the rear footwell.
· Registered
Discussion Starter · #13 ·
Ok, here we go: Project Cabin Airfilter, aka who the 🤬 designed this 💩!
Automotive tire Hood Vehicle Automotive design Automotive lighting
First surprise was this big plastic footrest. My QV didn't have one...
It's held in place by three nuts, one on top need a long 10mm socket, two are behind the plate at the bottom, which pops off by prying the bottom side (don't try to twist the top edge, it won't budge).
Ah, so that's what the pedestal is for: TCT control module hides under it:
Hood Automotive tire Motor vehicle Bumper Trunk
The sidepanel is removed also in that pic, pops off real easy by prying the rear seam. The grille at the bottom is fake, it's solid... After popping the three clips, pull the panel back and voilá:
Textile Sleeve Luggage and bags Bag Grey
Ok, to gain easier access to the filter, it's worth removing the footwell nozzle. One screw in outer part, then a firm yank towards the door and down, and it pops off:
Motor vehicle Hood Light Product Automotive tire
The old filter was not that bad, which made me happy as it confirms that the car had been well taken care of:
Watch Hood Grille Musical instrument Plant
As a sidenote: do not vacuum car floor in the middle of this process, at least if you stored nuts and bolts there...
Road surface Wood Art Asphalt Tints and shades
Ok, reason for vacuuming was, that while I was in there, I ran the AC at high speed and blasted the housing with compressed air. All kinds of stuff flew out... Btw, the the black lid pops off by gently pulling downwards from a clip at the bottom.
The new Bosch filter was considerably sturdier than its predecessor:
Hood Automotive lighting Automotive tire Eyewear Automotive design
Now, this proved to be a bit (not just a bit to be truthfull) problematic, as the filter must be molded into a curved shape in order to get it into the ridiculously stupid location.
Automotive parking light Hood Grille Automotive lighting Finger
I thought this was enough, but not even close...
Well, that's about that. After approx. five minutes of solid swearing I got the new filter in, put all back together, realized I forgot the footwell nozzle, reverse assembled a bit, reassebled, and tadaa. Not a 15 minute job the manual said, but then again, I had the ordeal with the vacuum, and "rinsed" the system while I was at it. Not fun, but done.
· Registered
Discussion Starter · #16 ·
Well, after grinding the entrance strairs in preparation for re-tiling, I decided I do not want to do anything dusty anymore. Today. Boredom set in, and I thought well maybe do something oily to balance things out.
So I popped the hood, and ripped out the PCV valve. Just to see how bad it looked after 100000km. Oh the disappointment, it looked very clean.
Watch Motor vehicle Automotive tire Automotive design Rim
Prying out the round plastic cover that hides the rubber diaphragm took a little bit courage to pop off, but otherwise a no-thrills job. Hmpf.
Rinsed the insides with some brake cleaner, and slapped it back on.
Well, at least now I understand why it looks so complex 😃
· Registered
Discussion Starter · #17 ·
Tried my luck at polishing a headlight: Left one has obviously been changed lately, as it is mint, the right one had this yellowwish tint to it, and some visible "rash" on the surface.
First I applied masking tape around the light, not to scratch the chrome frame, then a couple of minutes of firm sanding with 1200 grit wet sandpaper, good rinse and a couple of minutes with 2000 grit wet sandpaper, at first firmly, then rinsing and gradually lightening the pressure to very light touch.
Last step was polishing with Carlake cleaner wax (yep!). Took about 5 minutes maybe, firm pressure all the time. Kept applying small amounts as it dried out, then let it completely to dry and wiped it off.
Now the old light looks better than the new one 😳
Oh, and no powertools used in this one. Definitely the highest bang for the buck -ratio of anything I've ever done to the MiTo!
Stupid stupid stupid me, I didn't take any "before" -pictures 😐
· Registered
Discussion Starter · #18 ·
Guess I should drop a few lines of the double din Erisin 8730 head unit I installed last week:
Overall really happy with it:
  • easy to install
  • perfect fit
  • easy to use
  • navi has offline maps and multiple languages
  • screen is visible with polarized glasses
  • good sound adjustments
  • fast boot, a couple of seconds (first boot after battery cables off takes ~ 10 sec)
A few tips and tricks:
Remove the lower support brackets. They hit the blue and me module, and even if you don't have that, they make removing the new head unit difficult
Make sure the CANBUS module is type 02A, to make the steering wheel buttons work, go to
  1. Settings
  2. Car settings
  3. Factory Settings
  4. Enter Pin 126
  5. Canbus type
  6. Change it to selection - 17 FIAT (Simple, Union)
  7. Save and exit.
Kudos to @metalgod23 for solving this!!!
Secure the CANBUS module to the harness connector with tape and amke sure the wires are also secured such that the CANBUS connector remains pressed in. It does not have good latching, and will drop inside your dash 😏
For good radio reception you need a phantom power feed adapter:
Data transfer cable Usb cable Cable Auto part Font
I got this one (~10€) Check which connectors you need, I had ISO & DIN. The head unit has power feed wire labelled "Ant", solder it together with your adapter.
Only minor snag is, that there is a slight difference in the silver tone of the HU compared to the vent fascia above. Not much though
Gear shift Car Trip computer Steering part Automotive design
I'll post a follow-up when I drop in the reverse and front cameras. I got the whole bunch 😃
1 - 18 of 18 Posts
