Hi all,
I cant seem to find a way of removing the bulb from the holder! Im 6ft 2 and 18 stone so you might imagine I dont have the most gently of touch :)eek:) so Im concerend I pull off the wires if I keep pulling!
Please can someone point me in the right direction?
Many thanks.
Spongebob.
Dimmed H7s require turning the socket before pulling.
High H7 are just pull out.
With DRLs you take out the socket with the lamp and then remove the lamp.
Hi all,
Sorry, its the headlamp bulb.
I took the cover off, twisted the bulb and it came out.
Its trying to release the bulb from the holder I cant seem to do!
Many thanks.
Hi again,
Thanks for the replies, but still cant seem to seperate them!
Should I look for something to release the bulb as theres two blocks that seem linked?
Thanks again!
Spongebob.
No, the H7 comes with a circular metallic base, it is part of the lamp. That has 2 legs that go into the plastic socket. Maybe your has some plastic clip that you need to release? Mine didn't, it did required some force to pull off, but nothing more.
No idea, maybe post a pic of it?
