1 - 18 of 18 Posts
It's that time of year the MOT is due tomorrow, hoping it will pass without too much work. Limit is £250 or it's off to the scrap yard....
:cry:
Nice looking car from here and that's a bulletproof engine isn't it?
Would be a shame to see it scrapped. I'm sure someone on 155.org would be interested.
you will make a lot more in parts to other owners than scrapping it - as also mentioned, will help keep other 155s alive!
The only thing you should scrap it on is rust.
8 valvers are worth the effort to keep going, the engine's good for over 200k miles.
I've heard of one that did 400k!
Result
ABS light does not work.....indicating ABS fault?
Rear Brake pipes corrosive
Lamps too low/couple not working
Front Tyre
Handbrake inbalance
corroded front struts mounting
Movement in Rear brake pin/bearings
Failed emissions
Good news.
Anyone know more about the ABS?
Nice one.
I've been told I need new ABS sensors to pass the test over here. Maybe just replace the sensors?
Nice one.
Thanks I tell the guys at the garage.
Had the car 2 years with no problems and done about 12k, tyres, brakes, oil and filters keeps it going. v:thumbs:
they are located on the hubs towards the rear, just below the bottom bolt to the upright you'll see a wire going to them
Good luck getting them off !
Although this is risky - how about taking the abs warning light bulb out?
My 8v widey seems to have abs pumps etc, but the abs has NEVER worked in my ownership - front wheels will lock if I brake hard enough.
Someone has, I suspect, removed the warning light bulb.
Never been an issue at MOT time
all the requirement states is that the warning bulb is not illuminated - there is no requirement for the ABS to actually work that i'm aware of..
Had an ABS light come on a few years ago and spent a fortune getting a new sensor fitted and then hours of labour by the confused mechanic cos the ABS light wouldn't go out. Turned out to be a frayed wire in the bulk head sending a false signal. He did claim of course that the sensor did still need replacing anyway just to avoid removing it and giving me a refund i think - but worth a second look incase thats your problem??
Discussion Starter #17
ABS Problem
ABS light now working when the ignition is switched on, goes out when car starts then comes on and stays on when brakes are applied????
Any ideas?:confused:
1 - 18 of 18 Posts
