1 - 15 of 15 Posts
my 146 passed MOT :D before going in i had front discs and pads changed and changed my rear wheels with front wheels as there is more tread on them. i now have a steering issue. the steering wheel sits slightly to the right when going staight and the car pulls to the right.:confused: what have i done to cause this?
Check your tyre pressures for a start fella then check the condition of the tyres themselves, is one side very worn in comparison to the other etc. I know it may seem odd but are they the same tyre size?
Are the front tyres both the same? ie brand and tyre depth? Is there any possibility that one of the brakes is binding a bit? (Jack it up and spin the wheel to check)
When did you last have your toe-in checked and adjusted? It would be the first thing I'd look at based on what you say. Also worn out wishbone bushings can cause the toe-in to be off.
tyre tread are equal on both and same make. i will do the whell test. do you think the tracking may have been affected by replacing break discs ?
whats toe-in and how do you adjust it? both wishbones were changed last year.
Toe in is how much the front wheels point inwards. Too much toe in causes outer edge tyre wear. Uneven toe in causes uneven wear. It is adjusted at the track rod ends, and would normally need to be done if you change the wishbones (or hit a kerb!)
How many miles have your new brakes done? I would leave it for 200 miles of decent brake use and then review the problem again. I just changed my front pads and discs on the 306 and that was pulling all over the place for the first 20 odd miles, iv done 200 miles now and its nice and balanced.
Put some more miles under your belt fella.
:thumbs: went for drive and now steering is as staight as an arrow. (ps after reading many post on MOT failiers cant believe mine came through clean. nothing on the advisory note.)
hth
Banned
Same as mine last year, then the head gasket blew big time.
1 - 15 of 15 Posts
