Hi Guys,
Had the GTV go for its first MOT since I've owned it and.....it failed :biglaugh:
I was expecting a fail on one thing but there are some others that I wasn't expecting!
The list is:
Parking brake - efficiency is below requirements
Parking brake lever has no reserve travel
ABS System wiring excessively damage offside front (Bracket broken)
Steering rack gaiter split offside
Windscreen wiper does not clear windscreen effectively
Front CV joint gaiter insecure
Exhaust has major leak of exhaust gases front
The exhaust leak I was expecting so I put it through to see what else needed doing!
I'm a bit worried about the parking brake, don't know what no reserve travel means? The garage said that could be the rear calipers as the cable is free. The ABS wiring is also a concern, don't know if that means a new bracket or new wiring!
I'm going to order a new exhaust front pipe as well as some wipers. Any idea where I can get steering rack gaiters from and should I replace both sides?
The list is:
