Was driving home from work tonight when it startet to rain> Put the wipers on only to find the drivers one working! Had a quick look when i got home and the linkage has come off the wiperarm underneath. I pushed it back together but cant work out how it stays on is it a circlip or a split pin or something?
Depends on where the linkage has come adrift. If it below that wiper as Super says it is a ball and socket joint.
Drive fom the motor goes to a drive arm which is held onto the motor by a small nut clamping onto an angled spline.
Drive arm again has ball and socket joints.
Sockets are plastic from memeory so could perish and break out?
rsfruitbat
K
post a pic of the part you need, i do have a spare part or 2 for the linkages, may be able to help :cool:
K
i will try and get one dismantled tomorrow and post some pics of the parts.
let me know then which bit you want, think i know the parts you mean, a platic bush where the link clips in :confused:
should be able to help :thumbs:
